โšก Meet MaxForge MCP โ€” Your AI-Powered 3ds Max Assistant
BluntMan420
Message 1 of 1
BluntMan420
Community Visitor
Community Visitor
๐Ÿค–๐Ÿš€ I Built an AI That Can Actually Control 3ds Max โ€” Meet MaxForge MCP
What if you could tell an AI:
โ€œCreate the model, apply the materials, set everything up, and export it.โ€
โ€ฆand instead of getting a block of code to copy and paste, the AI could actually work with your live 3ds Max session?
That's the idea behind MaxForge MCP.
๐Ÿ”— GitHub: github.com/BluntMan-420/MaxForge-MCP
๐Ÿง  What Is MaxForge?
MaxForge MCP is an open-source MCP bridge that allows compatible AI agents to interact with a locally running 3ds Max session through its scripting environment.
The AI can inspect what's currently in your scene, make changes, and then continue working based on what actually happened.
Instead of:
AI โ†’ Generate Script โ†’ Copy โ†’ Paste โ†’ Run โ†’ Find Error โ†’ Repeat
You can have:
AI โ†’ 3ds Max โ†’ Inspect โ†’ Modify โ†’ Inspect Again โ†’ Continue
That's the part I'm really excited about.
โšก What Can It Do?
MaxForge currently supports a growing collection of 3ds Max operations, including:
๐Ÿ”Ž Scene Intelligence
  • Inspect the current scene
  • List scene objects
  • Read the current selection
  • Check scene units
  • Check FPS
  • Check frame ranges
๐Ÿงฑ Modeling & Objects
  • Create primitives
  • Position objects
  • Rotate objects
  • Scale objects
  • Modify existing objects
๐ŸŽจ Materials & Textures
  • Create materials
  • Load bitmap textures
  • Assign materials
  • Apply textures to objects
๐ŸŽฌ Animation
  • Position keyframes
  • Rotation keyframes
  • Scale keyframes
  • Frame-based animation
  • Spline interpolation
๐Ÿ’ฅ Collision Proxies
Generate basic collision proxies from scene objects for workflows where collision geometry is needed.
๐Ÿ“ฆ Exporting
  • Export selected objects
  • Export complete scenes
  • Save .max files
๐Ÿง  Advanced Scripting
There's also an escape hatch for situations where a dedicated MCP tool doesn't exist yet:
Run MaxScript or Python directly.
This makes MaxForge much more flexible than a fixed collection of commands.
โ†ฉ๏ธ And Yes โ€” You Can Undo It
One thing I specifically wanted was to make experimentation safer.
MaxForge wraps mutations in 3ds Max undo blocks, meaning changes can be reverted through the normal Ctrl + Z workflow.
So if the AI does something you don't like:
Ctrl + Z.
Simple.
๐ŸŽฎ Why I'm Building This
I'm especially interested in using MaxForge for GTA V / FiveM development.
Anyone who's worked on GTA/FiveM assets knows how repetitive some workflows can become:
  • Setting up objects
  • Moving and rotating assets
  • Creating materials
  • Assigning textures
  • Preparing scenes
  • Creating collision geometry
  • Exporting assets
  • Repeating the same operations over and over
The goal isn't to replace 3ds Max.
The goal is to make AI a useful assistant inside the 3D workflow.
๐Ÿ”ฅ The Bigger Idea
I don't want AI to just tell you how to do something.
I want to be able to say:
โ€œBuild this.โ€
โ€ฆand have the AI actually work inside the application.
MaxForge is my step toward that.
There's still a LOT I'd like to add, and this project is very much evolving.
๐Ÿงช Current Status
MaxForge has been tested against a live 3ds Max 2025 session with automated tests covering the available tools, error handling, and undo/redo behavior.
There's plenty more to build, though.
Some of the areas I'd like to expand include:
  • More advanced modeling operations
  • Better material workflows
  • More animation controls
  • GTA/FiveM-focused tooling
  • Additional exporters
  • Better scene understanding
  • More AI-assisted workflows
โญ Try It Out
The project is completely open source, and I'd love to get feedback from other 3ds Max users, developers, modders, and FiveM creators.
If you try it, let me know:
What would YOU want an AI to be able to do inside 3ds Max?
๐Ÿ› Found a bug?
๐Ÿ’ก Have an idea?
๐Ÿ› ๏ธ Want a new tool?
๐ŸŽฎ Have a GTA/FiveM workflow you'd like automated?
Drop it below.
๐Ÿ”— GitHub
โญ If you think this project is interesting, consider giving it a star.
MaxForge MCP โ€” Stop telling AI what to code. Start letting it work. ๐Ÿค–โšก
Replies (0)
