MAX 2023 keeps prompting close spline
hdizajn
Message 1 of 14
hdizajn
I have some imported dwg splines and every time I go to sub and only move or rotate them (so not creating anything) I get a prompt "close spline" and like 4 times since I guess it's detecting 4 vertices close enough to close. Should I report this as a bug or something?
Replies (13)
Message 2 of 14
sconzamirko
Community Visitor
Community Visitor
No solution yet
Message 3 of 14
RobH2
Can you upload the spline in a file so it can be looked at?
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 4 of 14
jibijib
Is it prompting to close when the two end vertices are snapped together?
What are they importing into Max as?
Message 5 of 14
ephb
Observer
Observer
This is still a bug in 2024. If anyone envounters this, enabling the automatic welding and setting welding treshold to 0 works around this issue.
Message 6 of 14
jibijib
... and you should be able to set persistant default using this:
https://cganimator.com/3dsmax-2021-1-custom-default-parameter-and-the-manager/
Message 7 of 14
ephb
Observer
Observer
To be clear, this is a bug.
Even though "automatic welding" is unchecked, it will still attempt to. The benefit of turning it on is that one can put a treshold so small it will never weld, but the feature can not be turned off.
Message 8 of 14
jibijib
... and there isn't a 'spline' reference (like there is for Editable Poly) to keep the setting persistent in any of the INI files or through other methods. Ugh.
Nothing like a pop up dialogue box to keep things working smoothly.
Message 9 of 14
RobH2
I would recommend reporting it:
Bug Reports:
https://www.autodesk.com/company/contact-us/product-feedback
Rob Holmes
Message 10 of 14
PuChiNgBaLLz
Max 2023, the issue is still there, it's incredible annoying to move or make flat a huge cad file, the prompt pops up for every one of the now...24957 vertices, and I dont want to turn off and on the welding threshold every time I use the spline tool, add 2 buttons Yes to all, No to All. Thats it
Message 11 of 14
MartinBeh
Can someone share a .max file or precise steps to reproduce this?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 12 of 14
RobH2
As a diagnositc, can you save your current ENU by renaming it and then relaunch Max to see if the issue persists?
Rob Holmes
Message 13 of 14
PuChiNgBaLLz
Something like this but with 10.000 times more vertices, it's one multi spline, with lots of open vertices cause we don't care about them, but the prompt is killing me.
Message 14 of 14
MartinBeh
@PuChiNgBaLLz - thanks, but it would be much easier for us if you could just share a .max file for us to investigate.
