3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
maxstart.max
2 REPLIES 2
nazmy2
297 Views, 2 Replies
maxstart.max
Hello. I know in order to change 3ds max's initial state, you need to alter the maxstart.max file. However, I don't know the steps involved. Can anyone help.
2 REPLIES 2
RobH2
in reply to: nazmy2
Go to your default project location and look in the 'Scenes' folder. See if you have a 'maxstart.max.' If so, load it and set it up the way you want it, scale, lights, etc. Then save it. If not, just open Max and set it up a file the same way and save it as 'maxstart.max'.  What I do now is go to it and back it up and change the backup name to 'maxstart.max.ORIG'. Now, take the other one 'maxstart.max' and right click on it. I make it 'Read Only' so it can't be modified by Max.
Now when you start Max you should have the starting file the way you want it.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
nazmy2
in reply to: RobH2
Thanks so much Rob.
