Announcements
MaxScript auto-load Script error
leeparkes3d
Message 1 of 8
leeparkes3d
Every time I start max I'm getting these errors. Fresh install of max 2022
Replies (7)
Message 2 of 8
CiroCardoso3v
Is this the first time installing 3ds Max 2022? Or is this a reinstall?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 3 of 8
leeparkes3d
First time. Uninstalled 3ds Max 2021 this morning. Installed 2022 and getting these errors.
Message 4 of 8
leeparkes3d
Message 5 of 8
CiroCardoso3v
Ok, I have seen this before. Give me a couple of minutes.
Ciro Cardoso
Message 6 of 8
CiroCardoso3v
The solution is for you to download the BulletSharp.dll. If you know someone that you trust and that has 3ds Max 2022, you can ask for that dll and then replace it.
Ciro Cardoso
Message 7 of 8
leeparkes3d
Thanks have just tried that. Error is still the same 😞
infuriating
Message 8 of 8
CiroCardoso3v
That is weird, there was another user that solved that issue by doing that. I believe this affects the MCGs in case you are using it. This bug was reported to the Dev team. I will keep you updated when I hear something from them.
Ciro Cardoso
