Message 1 of 1
Max Script code to display currently selected Material ID ?
- Mute
- Permalink
- Report
So I am trying to slightly modify this open script by hunter_sk, basically I just want the name of the currently selected material ID to appear after the ID number, which is already displayed on the top left part of the interface.
So far I've added the line (and moved everything downwards to leave a full line for ID name)
label nameID "" pos:[2,20]
but I can't figure out the other part (or parts?) that I need for the ID name to appear.
This is the script with only 8 buttons for readability, any help is greatly appreciated 🙏
macroScript h_idchanger
category:"Developer Tools"
icon:#("Material_Modifiers",6)
global id_changer
global id_changer_selectedFacesChanged
con = dotNetClass "system.windows.Forms.Control"
rollout id_changer "id_changer 1.5" width:162 height:185
label currentIDlabel "Selected ID:" pos:[2,3]
label currentID "-" pos:[68,3]
label select "select ID" pos:[117,3]
label countIDlabel "#:" pos:[2,83]
label countID "" pos:[15,83] align:#left
label st "set ID" pos:[131,83]
button b1 "1" pos:[0,20] width:20 height:20
button b2 "2" pos:[20,20] width:20 height:20
button b3 "3" pos:[40,20] width:20 height:20
button b4 "4" pos:[60,20] width:20 height:20
button b5 "5" pos:[80,20] width:20 height:20
button b6 "6" pos:[100,20] width:20 height:20
button b7 "7" pos:[120,20] width:20 height:20
button b8 "8" pos:[140,20] width:20 height:20
button m1 "1" pos:[0,100] width:20 height:20
button m2 "2" pos:[20,100] width:20 height:20
button m3 "3" pos:[40,100] width:20 height:20
button m4 "4" pos:[60,100] width:20 height:20
button m5 "5" pos:[80,100] width:20 height:20
button m6 "6" pos:[100,100] width:20 height:20
button m7 "7" pos:[120,100] width:20 height:20
button m8 "8" pos:[140,100] width:20 height:20
button ok "ok" width:150 height:16
on ok pressed do
if($!=undefined) do subobjectLevel = 0
fn clearCounters =
currentID.text = ""
countID.text = ""
fn updateSelectedID_ePoly =
sel=polyop.getFaceSelection $ as array
--update count
countID.text = sel.count as string
--some faces must be selected
if( sel.count<1) then
clearCounters()
return false
--get first selected face setMaterialID
matID = polyop.getFaceMatID $ sel[1]
allSame = true
for i = 1 to sel.count do
if( polyop.getFaceMatID $ sel[i] != matID) then
allSame=false
exit
if(allSame) then currentID.text = matID as string else currentID.text = "--"
fn updateSelectedID_polyMesh =
sel = $.modifiers[#Edit_Poly].GetSelection #face
countID.text = sel.numberSet as string
possibleID = 0
sel=$.modifiers[#Edit_Poly].GetSelection #face
if (sel[i] == true AND possibleID == 0) do possibleID = (polyOp.getFaceMatID $ i)
if (sel[i] == true AND (polyOp.getFaceMatID $ i) != possibleID) do return false
currentID.text = possibleID as string
fn updateSelectedID callback id =
--one ePoly must be selected
if( selection.count!=1 OR subobjectLevel!=4 ) then
clearCounters()
return false
if( (classof $) == Editable_Poly ) do updateSelectedID_ePoly()
if( (classof $) == PolyMeshObject ) do updateSelectedID_polyMesh()
fn removeFacesWithSpecificIDfromArray arr findId useBitArray:false =
for faceId = arr.count to 1 by -1 do
if (useBitArray == true) then
if (polyOp.getFaceMatID $ faceId == findId) do arr[faceId] = false
else
if (polyOp.getFaceMatID $ arr[faceId] == findId) do deleteItem arr faceId
fn selectID_ePoly id =
-- deselection
if (con.modifierKeys == con.modifierKeys.Alt) then
sel = polyop.getFaceSelection $ as array
removeFacesWithSpecificIDfromArray sel id
polyop.setFaceSelection $ sel
else -- select new or add (with ctrl)
clearSelectionBool = (con.modifierKeys != con.modifierKeys.Control)
$.EditablePoly.selectByMaterial id clearCurrentSelection:clearSelectionBool
fn selectID_polyMesh id =
sel = $.modifiers[#Edit_Poly].GetSelection #Face --bitArray
removeFacesWithSpecificIDfromArray sel id useBitArray:true
$.modifiers[#Edit_Poly].SetSelection #Face sel
else -- select new or add to selection
if (con.modifierKeys != con.modifierKeys.Control) then
$.modifiers[#Edit_Poly].SetSelection #Face #{}
$.modifiers[#Edit_Poly].selectByMaterialID = id-1
$.modifiers[#Edit_Poly].ButtonOp #SelectByMaterial
fn selectID id =
if (ClassOf($) == Editable_Poly) then
if (subobjectLevel != 4) then subobjectLevel = 4
selectID_ePoly id
if( ClassOf($) == PolyMeshObject) then
redrawViews()
fn setID_ePoly id =
$.EditablePoly.setMaterialIndex id 1
if( (polyop.getFaceSelection $ as array).count >= 1) do
currentID.text = id as string
fn setID_polyMesh id =
$.modifiers[#Edit_Poly].SetOperation #SetMaterial
$.modifiers[#Edit_Poly].materialIDToSet = id-1
$.modifiers[#Edit_Poly].Commit ()
if( ($.modifiers[#Edit_Poly].GetSelection #face).count >= 1) do
fn setID id =
setID_ePoly id
if (ClassOf($) == PolyMeshObject) then
setID_polyMesh id
on b1 pressed do ( selectID(1) )
on b2 pressed do ( selectID(2) )
on b3 pressed do ( selectID(3) )
on b4 pressed do ( selectID(4) )
on b5 pressed do ( selectID(5) )
on b6 pressed do ( selectID(6) )
on b7 pressed do ( selectID(7) )
on b8 pressed do ( selectID(8) )
on m1 pressed do ( setID(1) )
on m2 pressed do ( setID(2) )
on m3 pressed do ( setID(3) )
on m4 pressed do ( setID(4) )
on m5 pressed do ( setID(5) )
on m6 pressed do ( setID(6) )
on m7 pressed do ( setID(7) )
on m8 pressed do ( setID(8) )
on id_changer close do
id_changer_selectedFacesChanged = undefined
gc()
CreateDialog id_changer
id_changer_selectedFacesChanged = NodeEventCallback mouseUp:true subobjectSelectionChanged:id_changer.updateSelectedID
