Myself and my coworkers have encountered an issue with the newest update of Max 2019. When you load a render preset, any render preset and then press 8 to open the environment settings 3Ds max will crash. The little window comes up saying an error has occurred and the application will now close.
Has anyone else encountered this? Is this a bug or is there some sort of work around?
Thanks.
Solved by brentscannell. Go to Solution.
Hi @Anonymous
Thanks for letting us know.
There are a few instances of this popping up.
Also, thanks for submitting the CER crash report. I was able to dig around and find that development are aware and are currently working on the issue, but I was not able to find a workaround at this point.
Are you able to use an earlier version for now?
Hope you are well.
Unfortunately we have already updated our whole department to the newest version so it would not be easy to downgrade everyone again to an older version. The workaround we have been using is to load a render preset, save, close 3ds max and re-open it then everything seems to work fine.
Thanks for your reply, I guess we will have to wait till this issue is fixed in the next update.
Hi @Anonymous
Thanks for sharing those steps. They may help others for the time being until we get more information.
Sorry I couldn't be of more help.
Take care for now.
I have exactly same problem on latest verson of max 2019 . Does anyone in Autodesk working on 3ds max or all people are moved to finance department?
Hi @elPanki,
I hope you are enjoying your stay on the forums.
Thanks for letting us know that this affects you too.
I looked at the developers list and this has been addressed. I am not aware of the release schedule, but this should be out in a future update.
I am sure the team are grateful for everyone's patience on this!
Hi everyone, just a quick update to @raiden_xavier post: 3ds Max 2019.3 is officially live today and available for download from either the Autodesk Desktop App or through your account portal at manage.autodesk.com
Check out the blog post here:
https://area.autodesk.com/blogs/the-3ds-max-blog/3ds-max-20193-updates/
