3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
MAX 2022 railing problem
11 REPLIES 11
Message 1 of 12
RoySsgi
1024 Views, 11 Replies
RoySsgi
Greetings.
See Attached.
The problem does not exist in Max 2020
Greetings.
See Attached.
11 REPLIES 11
Message 2 of 12
RoySsgi
in reply to: RoySsgi
RoySsgi
same problem with max 2023.
Autodesk Please refer to.
Message 3 of 12
raiden_xavier
raiden_xavier
Autodesk Support
Autodesk Support
Hi @RoySsgi,
Thanks for sharing this with us.
Can you briefly explain the tools, the process, and how you arrive at this result?
I would like to try and replicate.
Many thanks.
Hi @RoySsgi,
Many thanks.
Message 4 of 12
RoySsgi
in reply to: raiden_xavier
RoySsgi
Thanks raiden.xavier
Here is a link to a video for railing made in MAX 2020
https://www.youtube.com/watch?v=RoXWK-UERKQ
As you can see - in Max 2020 there are no problems.
On the other hand, Max 2022 and 2023 have a problem - as can be seen in the following link
https://youtu.be/mzdVlmaYjTg
Message 5 of 12
RoySsgi
RoySsgi
Hey raiden.xavier
Was I clear in the videos about the problem?
Is there a solution to this?
Hey raiden.xavier
Message 6 of 12
raiden_xavier
raiden_xavier
Autodesk Support
Autodesk Support
Hi @RoySsgi,
Thanks for the videos.
I tried this on my 2020 and 2022.
I was not able to reproduce this.
Are you using any custom scripts, or installed plug-ins?
Perhaps disable everything and try it again in the stock/vanilla 3ds Max?
Disable plug-ins for testing LINK
Hi @RoySsgi,
Message 7 of 12
RoySsgi
RoySsgi
Thanks for the response R A I D E N _ X A V I E R
At Max 2020 the problem does not exist. It exists at Max 2022 and 2023
Attached is a link to a video showing the problem in Max 2023- where I did a clean install without any plugins. Also attach the Max file (2023)
https://youtu.be/aIzat1u1lcs
Message 8 of 12
RoySsgi
RoySsgi
Greetings.
Is there any news on the above matter
Greetings.
Message 9 of 12
RoySsgi
RoySsgi
Autodesk please
Can you deny or confirm that this is a bug?
Please your attention
Autodesk please
Message 10 of 12
raiden_xavier
raiden_xavier
Autodesk Support
Autodesk Support
Hi @RoySsgi,
Thanks for the follow up.
Apologies I was away on vacation.
I hoped someone with more experience in this particular area, or a member of the dev team had seen this and provided further assistance.
If more users confirm this, it is likely an issue with 3dsMax.
If it is just you, then perhaps something has gone wrong during the install, or a WindowsOS change, or a driver could be at fault.
Sorry I cannot be of more help at the moment.
Hopefully some other users can test?
I hope you are well.
Hi @RoySsgi,
Message 11 of 12
RoySsgi
RoySsgi
Hello forum members. Thanks R A I D E N_ X A V I E R
Can anyone do this test on the Max 2022 or Max 2023?
I think it's a bug, but I'd appreciate other people's tests.
Message 12 of 12
chrisbates7539
chrisbates7539
Observer
Observer
My team and myself are also experiencing the same issue. There's no issue in 2020 but in 2022 the railing pinches at the end. I tested something out wondering if the error was using spline imported from CAD (blue railing) vs spline created in MAX (purple railing) and maybe that's the issue others are having as well?
