Hi @RoySsgi,
Thanks for sharing this with us.
Can you briefly explain the tools, the process, and how you arrive at this result?
I would like to try and replicate.
Many thanks.
Thanks raiden.xavier
Here is a link to a video for railing made in MAX 2020
https://www.youtube.com/watch?v=RoXWK-UERKQ
As you can see - in Max 2020 there are no problems.
On the other hand, Max 2022 and 2023 have a problem - as can be seen in the following link
https://youtu.be/mzdVlmaYjTg
Hi @RoySsgi,
Thanks for the videos.
I tried this on my 2020 and 2022.
I was not able to reproduce this.
Are you using any custom scripts, or installed plug-ins?
Perhaps disable everything and try it again in the stock/vanilla 3ds Max?
Disable plug-ins for testing LINK
Thanks for the response R A I D E N _ X A V I E R
At Max 2020 the problem does not exist. It exists at Max 2022 and 2023
Attached is a link to a video showing the problem in Max 2023- where I did a clean install without any plugins. Also attach the Max file (2023)
Hi @RoySsgi,
Thanks for the follow up.
Apologies I was away on vacation.
I hoped someone with more experience in this particular area, or a member of the dev team had seen this and provided further assistance.
If more users confirm this, it is likely an issue with 3dsMax.
If it is just you, then perhaps something has gone wrong during the install, or a WindowsOS change, or a driver could be at fault.
Sorry I cannot be of more help at the moment.
Hopefully some other users can test?
I hope you are well.
Hello forum members. Thanks R A I D E N_ X A V I E R
Can anyone do this test on the Max 2022 or Max 2023?
I think it's a bug, but I'd appreciate other people's tests.
My team and myself are also experiencing the same issue. There's no issue in 2020 but in 2022 the railing pinches at the end. I tested something out wondering if the error was using spline imported from CAD (blue railing) vs spline created in MAX (purple railing) and maybe that's the issue others are having as well?
