- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've seen this problem dozens of times over the years but really didn't expect it to be an issue with the machine I'm on at the moment. Panning and zooming are super smooth but orbiting with either the mouse or orbit tool can freeze/lag for up to five seconds before updating the viewport. I've searched the forums high and low but none of the other suggestions has made any difference.
Spec: Ryzen 1800X/3.6GHz, ASRock Taichi, 32GB DDR4 3200, GTX 1080 w/ 384.94 driver
What I've tried/tested:
- Vanilla Max 2018 lags the same as Max 2017 with a normal setup (plugins etc)
- Nitrous DX11, DX9, legacy D3D and OpenGL all have the same problem
- Tried the last certified WHQL driver (369.26), no difference
- Panning and zooming are extremely fast (one primitive, 1000fps+), just orbiting is borked
- All view modes (Standard, Performance, High Quality etc) all freeze
- Maya 2018 is silky smooth and other apps have no issues
- Same problem in other user accounts
- Turning the grid off makes no difference
- DDU uninstall then a clean driver install didn't help
- Updating to latest chipset drivers didn't help
- Shaking fist at the screen didn't seem to do anything 😞
- No spikes in CPU usage whilst orbiting
- Changing various settings in the Nvidia control panel made no difference
- Reducing mouse polling rate to 125Hz (min) from 1000 made no difference
- 200 segment sphere with 5 iterations of Turbosmooth (40m polys) - slight lag (no freezes) with panning and the same issues with orbiting
- Disabling Enhanced Pointer Precision, View Cubes and Adaptive Degradation did nothing
- Stopping all non-essential services and apps didn't help
- I regularly do virus checks, all clean and the only thing running is Windows Defender
One odd thing I've noticed (a clue?!?) is that moving the mouse slowly seems fine but if I speed up it freezes. So I uninstalled my mouse driver bloatware (Corsair M65) but that didn't help, so I updated the chipset drivers in case it was USB related and that didn't do anything either, then I reinstalled the mouse software and lowered the polling rate as mentioned above, no joy.
Clean out of ideas so unless anyone has any suggestions, I'm off to cry in a corner somewhere*.
(* - or maybe try other random things in the hope something works)
Cheers,
triff
