Max 2015 impossible to delete layers
does anyone know how to delete layers in 3ds Max 2015? If i select them, rick click, and select delete from scene, nothing happens. Help page about new Layer Explorer is referring to some quad menu, but i am getting just regular windows context menu, no quad... 😕
Replies (24)
Steve_Curley
Well that's different... No such issues here. Tried clearing your preferences and letting Max create a clean set?
p.s. Your sig is out of date (Max 2012) 😉
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
I've spent a lot of time customizing Max 2015, actually several times in a row now, due to things like this. But this time, i would first like to know if there is some non-destructive way to solve it, before i wipe my config again 🙂
Steve_Curley
Worth trying anyway - just rename the ENU folder so you can go back to it later, just to see if that is the cause.
What I'd do is to start clean, make your changes gradually, keeping copies (zips) of that folder until you have it all working as you want, then make a final zip of it. At least that way if errors start to creep in you can restore a known working set of settings.
Max 2016 (SP1/EXT1)
lightcube
The Delete function in the quad only works on scene nodes.
To delete a layer, you can drag it "outside" the layer window area (to the menu section/border of the scene explorer). It took me a while to figure that out too. There should be a Delete Layer Button (as well as the old Add Selection to Layer button) like in old layer manager 😕
[EDIT] Well... this doesn't work after Extension 1. So it looks like we cannot delete layers anymore! It looks like an accountant made this decision--always leave a layer trail. 😛 Bug report time.
Shawn Olson
Developer of Wall Worm
3ds Max plugins and Scripts
3ds Max 4/Gmax - 3ds Max 2020
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
Steve_Curley
LOL @ the accountants 😄
However, I've just spent 10 mins creating and deleting layers. The Delete on the Quad Menu does work (for me), provided the Layer is empty (delete greyed out) and it is not the current layer (delete not greyed but does nothing). I can confirm that just dragging a layer off somewhere doesn't seem to work, but I never used that feature anyway so I'm not certain where I should be dropping it. I do have Ext1 installed btw.
Max 2016 (SP1/EXT1)
why AD do not keep delete button on the layer manager window ?
why when I nest a layer with objects in it, the objects don't stay in the nested layer ?
If you nest more than one layer at the same time, it is a mess !!!!
All features added in this layer manager have been tested ? really ? by whom ?
Give me his salary !!!!! I'll do it !!!
More than 700 euros for 2015.... I stop here or I will be "unpleasant"
lightcube
@Steve That's it... the Current Default Layer was always the layer I kept testing. My brain is still wired for the default layer having a checkbox. So the Delete function DOES work on layers... just not on layers that are Blue 🙂
And how do you send PMs to users in new forum. I was trying to contact you directly Steve and cannot figure it out anymore.
Shawn Olson
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
Steve_Curley
Click my name on the left, above my avatar. Scroll down the page and on the right there's a "Contact Me" section - click "Send this user a private message".
Max 2016 (SP1/EXT1)
Okay, so just resetting quad section of the user interface preferences did the job. I had to just recreate custom quads from scratch. I was surprised that hitting reset button on quads page did reset just quads, because from what i remember, it was always unpredictable, and most of the time i got reset also my toolbars, hotkeys and color scheme 😄
So again, after resetting quads to defaults, and restarting Max, i now get quad menu instead of context menu, and i can finally get rid of layers. Yay 🙂
Steve_Curley
Good to know, in case anyone else gets this particular problem 🙂
Max 2016 (SP1/EXT1)
VishnuR
Hi everyone,
Just got update from another user that resetting 3ds Max resolved this for him.
So maybe give this a try:
http://knowledge.autodesk.com/support/3ds-max-design/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Regards/VR
Vishnu Ramdass
I found the same problem and fixed it by selecting all in scene and creating new layer with it, I could then delete the old layers.
I know it's not really a solution if you're happy with a large scene and lots of layers organised how you want them.
Had the same problem here, solved it with these scripts:
http://cganimator.com/cslayerexplorer-extension-v1-0/
seem to work quite well and do the job
Hope it helps,
Tudor
It seems it was mainly getting used to the new layer manager... if the layer is active you can't delete it. Just make another one active by clicking on the little paper stack then right click the name of the layer to delete and click delete, job done. I prefer the old delete button myself but hey thats me, I also would like to not be able to create geometry on a hidden layer or in fact a group head in a hidden layer, after all why would I want to?
Make sure the layer you are right clicking and deleting is not the current layer - aside from this, the new layer system is horrible - wasn't broken and they messed around with it.
jens.diemer
rawalanche schrieb:
I've spent a lot of time customizing Max 2015...
This is IMHO generally a bad idea...
Jens
https://github.com/jedie/3dsmax_bugs | https://github.com/jedie/3dsmax_patches
Yes, sorry. I haven't been here for a long time. So i resolved it by resetting quad menu settings. You don't have to completely reset Max, just reset quads.
Turns out the problem is that if you migrate your settings from previous Max install, mainly UI settings, then new Max will import file with old Quad Men description. The old Quad Menu description will miss the new Layer Manager quad menu, and on right click, will display regular context menu instead, not quad. And this old context menu does not have delete option in it.
Steve_Curley
Which is why migrating settings from a previous release is decidedly not recommended, and also why there's an outstanding Uservoice request for the ability to import them.
Max 2016 (SP1/EXT1)
Hi, i did some test, and it works Smiley Wink
