3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
MAX 2011 x64 0xc000007b ERROR
22 REPLIES 22
Message 1 of 23
1676 Views, 22 Replies
Why does max 2011 x64, still gives same error (0xc000007b) as max 2010 x64 , on WIN7 ultimate?
Maya and softimage new versions run perfectly. So why does this happen with MAX?
Hope someone from autodesk can clarify this, as it is very annoying and affecting many people!
Regards
22 REPLIES 22
Message 2 of 23
Steve_Curley
Got Norton installed? Disable Symantec Endpoint and see if that fixes it.
These are peer-to-peer forums - little involvement from Autodesk directly, so don't hold your breath waiting on an answer from them.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 23
ekahennequet
According to Ken Pimentel in below (link) thread, the problem was Window 7 running 2010. Does anyone know if this problem was solved with subsequent hotfixes or with 3ds Max 2011 release?
There are some Win 7 specific bugs popping up. We haven't released fixes to these at this point. Win 7 is not officially supported at this time.
Link to thread: http://area.autodesk.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-max-design-2010/3d-max-x64---0...
Message 4 of 23
in reply to: ekahennequet
Thx for answering. It s exactly same error as MAX2010. Still is happening in 2011 x64.
What is weird is that maya and softimage run perfectly. Only max has this error.
Where is the catch?.-.... Something is deeply wrong. It was fixed for maya and softimage, but not max.
Very nice
Message 5 of 23
You want to know where is the catch?
There it is. I've got the same error message as you do, but after I uninstalled 3dsmax 2011 32 bit and 64 bit + component of each. Then I reinstalled them to the default location and everything worked fine.
Let me know if this resolve your issue.
Message 6 of 23
I am having the same problem with Maya 2011 x64 running on Windows 7. I have already installed windows 7 itself twice but the problem persists. Dont know whats wrong. Scanned everything with updated Nod32, installed latest version of DirectX, updated Windows, installed the latest nvidia drivers.
btw, is it somehow related to "adlmint.dll"?? For some unkown reason, the autodesk setup is creating adlmint.dll, adlmint_libFNP.dll & two folders en-US & ja-JP on my 😧 drive for no apparent reason!
Message 7 of 23
I would like to think that autodesk shared componets such as licensing services and other files can cause this problem. I know for a fact that if you install older autodesk product after installing recent once you will have problems.
For example if you have Max 2011 and later install Image Modeler 2009, you are in trouble
Message 8 of 23
Ok after countless hours of scanning for viruses and looking for answers i found out that:
It is not virus that any of anti-virus software can detect.
It is not the order in which Visual C++ 2005 and 2008 was installed
It was one of DirecX DLL files
For DirectX 9 MAX display drivers i think files was d3dx9_39
Not sure about Max directX10 display driver
Or any of these
d3d10.dll
d3d10core.dll
d3d10level9.dll
d3d10warp.dll
d3d10_1.dll
d3d10_1core.dll
d3d11.dll
d3d8thk.dll
d3d9.dll
D3DCompiler_33.dll
D3DCompiler_34.dll
D3DCompiler_35.dll
D3DCompiler_36.dll
D3DCompiler_37.dll
D3DCompiler_38.dll
D3DCompiler_39.dll
D3DCompiler_40.dll
D3DCompiler_41.dll
D3DCompiler_42.dll
d3dcsx_42.dll
d3dx10.dll
d3dx10_33.dll
d3dx10_34.dll
d3dx10_35.dll
d3dx10_36.dll
d3dx10_37.dll
d3dx10_38.dll
d3dx10_39.dll
d3dx10_40.dll
d3dx10_41.dll
d3dx10_42.dll
d3dx11_42.dll
d3dx9_24.dll
d3dx9_25.dll
d3dx9_26.dll
d3dx9_27.dll
d3dx9_28.dll
d3dx9_29.dll
d3dx9_30.dll
d3dx9_31.dll
d3dx9_32.dll
d3dx9_33.dll
d3dx9_34.dll
d3dx9_35.dll
d3dx9_36.dll
D3DX9_37.dll
D3DX9_38.dll
D3DX9_39.dll
D3DX9_40.dll
D3DX9_41.dll
D3DX9_42.dll
x3daudio1_0.dll
x3daudio1_1.dll
X3DAudio1_2.dll
X3DAudio1_3.dll
X3DAudio1_4.dll
X3DAudio1_5.dll
X3DAudio1_6.dll
X3DAudio1_7.dll
xactengine2_0.dll
xactengine2_1.dll
xactengine2_10.dll
xactengine2_2.dll
xactengine2_3.dll
xactengine2_4.dll
xactengine2_5.dll
xactengine2_6.dll
xactengine2_7.dll
xactengine2_8.dll
xactengine2_9.dll
xactengine3_0.dll
xactengine3_1.dll
xactengine3_2.dll
xactengine3_3.dll
xactengine3_4.dll
xactengine3_5.dll
xactengine3_6.dll
XAPOFX1_0.dll
XAPOFX1_1.dll
XAPOFX1_2.dll
XAPOFX1_3.dll
XAPOFX1_4.dll
XAudio2_0.dll
XAudio2_1.dll
XAudio2_2.dll
XAudio2_3.dll
XAudio2_4.dll
XAudio2_5.dll
XAudio2_6.dll
xinput1_1.dll
xinput1_2.dll
xinput1_3.dll
XInput9_1_0.dll
Dll could get infected with some virus but the fact that no anti-virus in the world was able to detect any infection (which is no surprise due to viruses changing executable code and reversing it is not possible because each executable is unique) if virus made changes and moved on to next target or even killed its self at the end leaving no trace.
But i still think that at some point directX files were damaged or replaced by some crappy software i installed.
BTW my problem is now gone.
I hope this helps
Message 9 of 23
I have never had any problems with 3dsMAX 2010 or 2011 on Win7 64bit Ultimate. I do know it is critical that that NOTHING is running when you install (shut down / disable all back ground programs, especialy virus and firewall software). Follow the installation instructions to the letter and all should be OK 🙂
Message 10 of 23
sometimes it gets more complicated than this.
For instance my windows setup is automated (i wrote my own script for deployment) and directX is not installed but rather DLL files that are extracted during DirectX installation are placed into System32 and SysWow64 folders.
Somewhere along the way 1 or more of those DLL files were corrupted or not in the right place caused this error for me.
I tried to scan for viruses/reinstall DirectX/Reinstall Visual C++ and Net Framework and Max2011 even tried switching to 32bit and nothing helped.
In my case i know for sure i had DirectX DLL files related problem. It took me a while and several windows reinstall processes to narrow it down to this conclusion so i thought it might help to some people.
If your system is setup not the conventional way then you might want to consider following my steps by erasing DirectX DLL's and reinstalling DirectX, after all that was the only thing that helped.
IN the end this was just another way to deal with this problem and so far i have not seen any solutions that actualy fixed this problem. Well there was one, but it was Virus which could not be a part of my problem (i dont have viruses because i dont download them in the first place thanks to firefox addons)
Message 11 of 23
In the end i narrowed it down to D3DX9_39.dll in system32 folder.
I erased file and reinstalled DirectX and then it worked.
Message 12 of 23
Never had this issue during any of my past installations of Windows 7 x64 + Max 2011 x64.
Came across it today and "Agreed" with looser.
It's related to an installation error of the "D3DX9_39.dll"
During my 3ds Max installation the DirectX 9 installation part failed but the rest continued as usual.
Just delete the "d3dx9_39.dll" file from System32 and SysWOW64 folders inside the Windows directory.
Download and install the latest DirectX9c from Microsoft or use the websetup if you have it.
http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displa...
Cheers.
Hope this helped.
Kudos to looser.
Message 13 of 23
HI GUYS. I HAD THE SAME PROBLEM BEFORE I INSTALLED 32BIT AND 64 BIT IN THE SAME DIRECTION. TRY TO INSTALL THEM TO THE DIFFERENT DIRECTORIES. I TRIED AND IT HAS BEEN FIXED UP. 🙂
Message 14 of 23
Message 15 of 23
Steve_Curley
I'm not surprised that failed - you must never install 2 versions in the same folder, that is just asking for trouble.
Max 2016 (SP1/EXT1)
Message 16 of 23
thanks man!! it worked for me too!....
Message 17 of 23
For everyone getting the "could not start the application - error (0xc000007b)" with Maya 2010/2011:
It seems this is a problem with some Autodesk products, including Maya, and Windows Vista/7, possibly moreso with 64-bit.
After searching for like two hours, I found a solution that worked for me:
Go to C:\Windows\System32 (and C:\Windows\SysWOW64 for 64-bit windows) and delete all .dll files that start with "d3dx__" followed by the directx version and some number, 24-43 for me. Apparently one or more of these directx dlls is corrupted.
Then, download the DirectX End-User Runtime Web Installer
here: http://www.microsoft.com/downloads/en/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3
This will find what files are missing, and download/install them.
Then Maya should hopefully work. Maybe 😄
Before trying this, I reinstalled the .NET framework and a few other things that I don't think helped, but might have. So if the above steps alone didn't fix the problem, try others' suggestions.
Message 18 of 23
as minkus said delete (all d3dx_) d3dx9_24 to d3dx9_49 from sysWOW64 and system32 solved my problem and then update ,, other methods didnt no netframe updated
Message 19 of 23
After deleting all these dll, I get again error message(0xc000007b).
Now what to do!
Message 20 of 23
OK, I just installed 3ds max 2012 x64 & it's working without any problem..... Thanks God! :-O)
Technology Administrators
