3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
make object more transparent in see through
6 REPLIES 6
100983 Views, 6 Replies
is there a way to make an object more transparent when see through mode is toggled? it is difficult for me to see through the object and wanted to set the transparency to like 25 instead of 50
6 REPLIES 6
companioncube
object properties > visibilty
Steve_Curley
Apply a Standard Material, animate the Material's Opacity - you can then vary the opacity of the object by scrubbing the Time Slider. I don't know of a way to alter the opacity of See Through mode (Alt+X) though you can change its colour in the Customise User Interface dialog.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
see the visibility option in this panel change them to lower probaly 0.0 u can see object u have been selected like wireframe.u can go to this panel by left clicking object and go object properties
in reply to: companioncube
See-Through option is completely different than changing the opacity.  How do you make a plane transparent so that you can still see the plane to mold the working plane into the object on the pattern? Band-aide fixes are not fixes,  please update your response with a valid response to help.
jon.bell
Just reviving this thread here. Whenever I've had to apply "blueprint" bitmaps to Planar objects to aid in modeling, I've tended to use the suggestions posted here -- apply a Standard (Legacy) material to the Planes, make it self-illuminated and adjust the opacity so I can see through it but still be able to discern the bitmap details for modeling. (Then for test renders, I usually turn off the Plane's render properties.)
Please let us know if this helps!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
