Hi there,
2023 2.2 many many times crashing. ı want to ask if I am alone on this topic ? I guess I am not alone
You're not alone, 2023.2.2 crashes when closing the render setup dialog.
Don't you mean that Corona crashes 3dsmax when you close the render dialog?
Best Regards,
Alfred (AJ) DeFlaminis
That's probably correct, I was not aware of that. But it does seem like neither Autodesk nor the Corona team will provide a fix, maybe the only solution for me is to wait for Corona 9.
Posted by a developer at Corona forums:
"As I said before, this is an Autodesk bug and really needs to be addressed on their side.
We managed to patch it for the v9 daily builds, but right now don't have plans to port it back to v8."
Fair enough. Make sure to file a support ticket through manage.autodesk.com then, that will help to get the issue some extra traction outside the forums.
Best Regards,
