Is there an alternate method to assign texture maps to models?
I believe I accidentally may have found a way to assign a texture map to a model. A way which does not rely in the standard Slate Material Editor.
I acquired this model of a bulldog:
     English Bulldog Real-Time Low-poly 3D model
It comes with a number of texture maps, for its skin:
By now, I know how to assign those. BTW: I only care about the main one.
 Next, I hired a Freelancer which performed some value added and delivered these two files:
    BullDog.max
Somehow, the MAX file knows about the existence of the *.jpg map. The string "Bulldog_texture_NEW.jpg" is inside it. The command "Asset Tracking" shows such dependency.
However, the Slate Material Editor is empty.
So: how did the Freelancer perform the linking between the clay model and its hide?
TIA
miledrizk
Probably he merged the geometry in a new Max file,
When you do that the objects materials will not show up in the material
Editor.
To fix that, in the Slate Material Editor, click the eyedropper labeled "Pick Material From Object",
Now click on the geometry and you'll see the material that belongs to the picked object is now
In the Slate Editor.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
