In the middle
In the middle
papaf1
In the middle
papaf1
Does anyone know if it’s possible, in 3ds max, to constrain an object to stay in the middle of two other objects, no matter where they move? I want to align a helper object to be the pivot of two moving objects.
D.R.
3ds Max 2014/2017
Autodesk Inventor & AutoCAD
HP xw8600 Workstation
Windows 7 64Bit
Dual Intel Xeon 2.83 E5440 GHz
8.00 GB of Ram
Brock_Lafond
Select your main object that you want stuck between the other 2. Create a position constraint for both of the other objects. Make sure the weight is set to 50 for both; should be done by default.
Alias/Wavefront Maya 3 -> Discreet 3DS Max 4 -> ...
Win7 Pro 64
EVGA Classified Super Record 2
Dual Xeon Hexa-Core, 48GB RAM
GTX 780 x 2
Corona Renderer, mental Ray
papaf1
Thank you for the reply. This is just what I was looking for.
D.R.
3ds Max 2014/2017
Windows 7 64Bit
8.00 GB of Ram
