Hello, I recently had an issue where Backburner spontaneously stopped rendering. I am running Max 2015 with the most recent service packs, and Vray 3.0
Everything has been going just fine, and I had 3-4 render jobs in the queue. All of a sudden machines woud no longer render.
The first was my primary workstation. I would shut down server to continue working and when I restarted at the end of the day, it would not connect. Machines that were connected and rendering would continue. Then all of the jobs finished and I shut them down. Now none of them connect. They all display the same error message.
Error sending on UDP to 192.xxx.x.xx: An address incompatible with the requested protocol was used (0x273f)
I have found information that is is related to IPv6, and to disable the 6TO4 adapter. Only my main workstation had the 6TO4 adapater, and after disabling it, I get the same error message.
Solved by BenBisares. Go to Solution.
I wouldn't disable the 6to4 adapter, rather I would use the "prefer IPv4" fixit from Microsoft which can be found here ( http://support.microsoft.com/kb/2533454 ).
As usual this would need to be applied to all machines in the farm.
Tell me if that works
I followed the instructions an copied this to the Administrator CMD Line one all machines but it didn't solve it.
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters" /v DisabledComponents /t REG_DWORD /d 0x20 /f
This was supposed to disable ip6 in favour of ip4. which I think it did.
