I need help with NOISE MAP
Gerardo_Guarino
Gerardo_Guarino
 Ok, I just started a model yestarday and it's all ok...now i need to put a turbulence noise map to a object, i set all the options and in the material editor the material i created is this: https://ibb.co/cBPUXw
Ok, the material in the image is just the thing i want but when i render a object with that map for some reasons this thing happen: https://ibb.co/dPB9Xw
  The problem is that: I want a object like the first image link...i saw many models like i want, some help please? I really need this.
PROH
Hi. TWo things:
1) The "size" value for your noise is far to high. Max won't always show the correct result in the viewport nor in the material editor. You'll have make test renders to find the right size.
2) I think the pattern in your reference picture is made by a cellular map (not a noise map)
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
leeminardi
To help me assess the scale of the mapping when using a noise map I first like to use a checker map.  I can more easily evaluate the scale and if the type of mapping is correct.  I then change the checker map to a noise map.
lee.minardi
PROH
Hmmmm... doesn't make much sense to me, since the checker-map is a 2D-map which requires a UVW-map and the noise-map is a  procedural 3D-map that works in object- or world-space.
But anyway.... this doesn't change what I wrote in my first post 🙂
Hope it helps
3dsMax 4.2 to 2018
leeminardi
In the image below I converted the teapot to an editable mesh and applied a UVW Map modifer.  All the teapots in the top row have the same checkered material applied but with different types of UVW mapping (planar for the first two, then box, box, shrink).  The UV tile values for each object change as well.  The 4th teapot has a small value thus you only see one checker.
The 5 teapots were then cloned/copied to form the bottom row and a noise mapped material was applied to replace the checkered material.  The point in my previous post was that having the checker pattern helped visualize how the UVW mapping of the noise map was being applied more so than just looking at the amorphous noise pattern.  Although the noise pattern is procedural it still uses a tile like approach to fill an area.
lee.minardi
kgokhangurbuz
Hi @Gerardo_Guarino;
If you'd like to achieve the same mapping in your Material Editor with your scene, please do the following:
-Go to the Noise channel of your material (in your case).
-Go to Coordinates
-Change Source type to "Explicit Map Channel
Kind regards;
Gerardo_Guarino
Thanks!
