How To remove White boxes around Object
Message 1 of 11
I created a 3d Character model in Make Human and imported in 3dsmax for animating but i can barely see my character with these boxesScreenshot (50).png
so how do i remove these boxes ??
Replies (10)
Message 2 of 11
There are two types of such brackets in 3ds max
The first type is Selection brackets. Until max 2017 their controls were in viewport [+]  -> configure viewports -> visual style -> selection brackets checkbox
The second are an animation brackets which indicates existing keyframe in current frame. Find their controls in menu -> customize -> preferences -> animation -> key bracket display. You can try setting it to 'None'.
Message 3 of 11
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
@Anonymous has a great post with good information.  You can also press "J" to turn off those bounding boxes.
Best Regards,
Message 4 of 11
Jixal
In 3DS Max 2020, this hotkey has been changed to Ctrl + J.
Why? For years it was just J. I had to google what the name of it was, then hunt it down in the keyboard list because the same hotkey that was used for years suddenly changed to a different one.  Total waste of time....
Message 5 of 11
senorpablo
Amen. There are many similar examples of needles changes to UI and or shortcuts.
Message 6 of 11
widdwsn2
odd, it was Shift+J for me(?)
Max 2020
Message 7 of 11
Shift+J in max 2021
Message 8 of 11
broodwar1126
Community Visitor
Community Visitor
it is shift+J for 3dsmax2021
Message 9 of 11
artisansofpathos
I have had a similar issue with importing FBX models from Blender to Max then seeing this god awful amount of boxes drawn on every dummy/bone on my models. By following what Pavel stated:
I was able to hide the stupid things and get to work. Spasiba, Pavel!
Message 10 of 11
kenvidavida14
Halow sir. How to fix when i import model only 1 animation is showing instead of 3
Message 11 of 11
hamoodpg
in 3ds max 2023 it's shift + J now I still don't know why but good luck everyone ^^
