How to remove a tex/script from a file ?
How to remove this text down there?
hagen.deloss
Hello @Anonymous
Thanks for bringing your question to the forums, it looks like you are visiting as a new member to the 3DS Max forum. I want to extend a warm welcome to the Autodesk Community!
In regards to your question, I'm wondering, does this information only pop-up when you have your statistics view turned on, or is this always present? What version of 3DS Max are you using?
Does this information change depending on what file you have open? I have never seen this information pop up before, is it displaying your personal information?
The better I understand the issue, the better I can help out 😄
I look forward to chatting with you more!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Thank you very much
3DS max 2017
Yes it’s always there , like it’s attached to this file
It’s not for my program , this test is attached to this file which is a tea pot , where ever you open it and merge it , this text will come with file
I was told this text has been added to this file via script but I don’t know how to edit it .
miledrizk
If you press H on the keyboard do you see an object called "sliderManipulator"?
If so, select it using the dialog and delete it.
If this doesn't solve it for you, maybe you can select the objects that you need,
Then use Export Selected, and export your objects as an obj then import them again.
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Thank you very much ! the first method worked !
just a question , how can i add such thing to my file?
miledrizk
Simple:
1- Go to Helpers, and from the drop-down list choose Manipulators, then Choose Slider,
    Click anywhere in the scene to place it.
2- If you want to prevent the user from selecting it by mouse, drag the Y Position slider all the way up
    Until the Value is 1.0, and Check the Hide option. Now you shouldn't be able to see anything.
    You can use the X Position value to control to horizontal placement of the slider
3- Now start typing in the Label area
Note: this tool is not made for this purpose. The Slider can be used to control other objects parameters
By using the Wire Parameters tool. A nice way to control many objects parameters just by a simple slider
On the Screen.
You can check YouTube for tutorials regarding the use of this feature in Max.
[email protected]
hagen.deloss
@Anonymous
Yaay I'm happy that @miledrizk suggestion helped out!
I have never used that tool, thanks for the educational post 😄
Hagen Deloss
