3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How to put picture in 3DS Max ?
30 REPLIES 30
Message 1 of 31
65797 Views, 30 Replies
Hello, I am attempting to make a ship via 3DS Max and I wanted to emulate one based on a picture. How can I put a photo like the one in the video?
https://www.youtube.com/watch?v=bzzaasKKbXw
30 REPLIES 30
Message 21 of 31
in reply to: irishman_team_kilber
Thank you for trying to help me out. You really had patience and you both deserve a medal. I am still having problems, like with the download you sent me tony.  I am going to video tape the process now. I just can't get it to work.
https://www.youtube.com/watch?v=G2VotRAa93U&feature=youtu.be
Message 22 of 31
in reply to: KurtNeuburger
Message 23 of 31
@KurtNeuburger i did it twice but it still says it missing! ARRRR ship image attached
Message 24 of 31
Here is the video of me showing the plane not being affected by the picture
https://www.youtube.com/watch?v=HfiKi_bYuA0&feature=youtu.be
Message 25 of 31
Bump
Message 26 of 31
Hello, I still haven't been able to complete the basic plane application for the material editor. I have unfrozen the Plane and the material editor still wont apply the photograph. Additionally I can't seem to edit the EditablePoly button to only have four sides of a square
From 0:00 to 2:00
Message 27 of 31
KurtNeuburger
I'm really not sure how to help further on this one. If you open the file @irishman_team_kilber posted, everything should work just fine. Sorry man!
Message 28 of 31
hagen.deloss
Hello @Anonymous
I wanted to check in, it's been a little while and wanted to see if you were still having issues with applying the material to the box object? Here is a video that walks through how to map an image to a material, and then apply that material to an object.
After applying the material to your object, if you are still having an issue with the image repeating, you can try putting in a larger number into the tiling option within your bitmap options, that would look similar to this in your slate material editor.
I hope this helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 29 of 31
You're a legend, step by step and beyond clear and concise. Thank you!
Message 30 of 31
Youe are te best 🙂 That was so easy 🙂 thank you
Message 31 of 31
jon.bell
in reply to: J.J.Kucharczyk
Hi everyone,
Just reviving this post to note that if you want a quick list of 3ds Max tutorials, resources and asset files, please check out this link. Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
