How to determine the version year of a .max file?
This is a problem that I face with all 3D applications. Is there are way to find the version (2017? 2018? 2019? 2020?) of a given MAX file?
TIA
-Ramon F. Herrera
ps: After trying 3ds Max 2019 and 2020, I decided that the latter runs great.
DanielCantin
Hi @Anonymous
You can use the MaxFinder executable (C:\Program Files\Autodesk\3ds Max 2020\MaxFind.exe), browsing to the folder containing the .max files > press Start > double click on the 3ds Max files you want to check the version, this can also be used from inside 3ds Max, see this Autodesk Knowledge page for more details: How to identify which version of 3ds Max a scene was created with
The complete versions number will vary for each update, service pack, etc. released, the second value will always be 0 for the first release of that version and will generally increment by 1 for each update, service pack, etc. released
3ds Max 2020
  • Build:    22.x.x.x
3ds Max 2019
  • Build:    21.x.x.x
3ds Max 2018
  • Build:    20.x.x.x
3ds Max 2017
  • Build:    19.x.x.x
3ds Max 2016
  • Build:    18.x.x.x
3ds Max 2015
  • Build:    17.x.x.x
Thanks for reaching out with your question, please let us know if that solution work or not for you.
-Daniel
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, ECP
hagen.deloss
Hi @Anonymous
Any ideas or questions on @DanielCantin 's previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
