I saw a video where, with just 1 click, is possible to create a hole.
Look the attached IMAGE
How do ?
Solved by kennyj. Go to Solution.
Hello AkenStyle,
That isn't a hole, that was a face removed.
The geometry was converted to an editable poly (or mesh), then with face select, they picked the face they wanted and hit delete. You can delete each face when you have face select (red box with the yellow highlight on the right side of your example image) on. Be sure to turn off this option when you are done.
Hope it helps,
Kenny
