How do I make an object not appear in final render?
Hey I'm doing a ragdoll simulation with MassFX and don't want a plane to show up in final render. Is there a way It can still serve it's purpose as a kinematic object while not being visible in final render?
Thanks! I'm kind of stuck on this one.
Out-Of-Light
The simplest way is to select the object you want to be invisible in the render, then right click and select object properties..
If By Layer is highlighted under Rendering Control, change it to By Object by clicking on it.
You can then uncheck Renderable to make it invisible to render, casting shadows etc, or individually uncheck visible to camera, if you want it to still cast shadows, visible in reflections etc.
You can also make an object appear see though by adjusting the visibility spinner from 0,0 ( invisible ) to 1.0 solid.
Some of these settings will not work correctly depending on the renderer you are using.
Another method is to apply a material to the object, set things like reflections and glossiness to zero, and make it 100% transparent., but I think the first method is probably what you are looking for.
Hope that helps.
• 3ds Max 4.2 though to 2026 / MudBox 2020 / Fusion360
• Gigabyte Aorus Xtreme TRX40 Motherboard
• AMD Threadripper 3970X processors (32 core / 64 thread )
• ThermalTake custom cooling solution
• 128GB G.Skill DDR4 3600Mhz Quad Channel Memory
• 2x Nvidia Titan RTX 24GB GPU's +NVlink
• 2x Asus PG348Q 3440 x 1400 IPS Monitor’s
• Wacom Intuos Pro large graphics tablet
• 4TB Sumsung 990Pro NVMe (OS/App's)
• 2TB Seagate FireCuda 520 NVMe (Projects)
• 1TB Seagate FireCuda 520 NVMe (Media)
• 6TB Toshiba HDD (Storage)
• CORSAIR 1600W PSU
• Pioneer Blue-Ray Writer(External)
• Roccat Leadr Mouse
• Roccat Vulcan 121 Keyboard
• Lian Li D011 Dynamic XL case
• O/S Windows 11 Pro x64 24H2
• iLoud MTM MKII Monitors
zhenyalisachenko699
Community Visitor
Community Visitor
Thank you for help. It's really helped me
