Recently all my rollover tooltips changed from English to Chinese....possibly a 3rd party script triggered it?
How can I change the tooltips back to English?
Thank you
I solved it....it was under Render Setup > Settings > System> Language....then select the preferred tooltip language from the dropdown. ....and restart Max to take effect.
Hi @Anonymous
Glad to hear you fixed the problem and thanks so much for sharing the solution! This will benefit other users in the community with the same issue.
