How do you minimize all Main UI toolbar windows?
R1F
R1F
Hi!
Trying to organize my workflow a bit.  I'm finding that I have to "minimize" and "maximize" the mini UI windows again and again.   (Pretty much everything on the Command panel - e.g. Modify, heirarchy tab etc. etc.)  It's getting very burdensome!
Anyone know how to set the default to minimize ALL these windows?  In this way, I can only open what I need..
Screenshot is attached.
Your help is much appreciated!
R  (3ds Max v.2021)
raiden_xavier
Hi @R1F,
Thanks for sharing your issue with us. I hope you are making connections on the forum!
It sounds (and looks) like you want a 'collapse all' or 'expand all' button for the parameter rollouts in the command panel.
Is that correct?
I haven't seen anything like that, so unless someone has figured it out I think you have 2 options:
#1 Request the feature in the Max idea area.
#2 Search a site like scriptspot.com. I believe commissions can be done there?
Perhaps someone with more knowledge may chime in here.
Please let me know your thoughts.
Hope you are well.
R1F
Thanks Raiden. Yes I think you've understood the issue. I have now added this as a 3DS Max Idea:
https://forums.autodesk.com/t5/3ds-max-ideas/quot-collapse-all-parameter-rollouts-quot-button-in-mai...
If anyone knows of any solutions/effective work arounds in the meantime, feel free to share!
RobH2
If you right-click on a group there is an 'Open All' and 'Close All' button at the top. Is that not suitable?
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
RobH2
One more tip that might help. It's often overlooked and unknown but you can increase the number of Command columns by dragging the left edge. I leave it constantly at two columns. But, I have large multiple monitors and plenty of real estate. On a laptop or smaller monitors, that eats up viewport space.
But what's useful is that you can use many columns to work with programs that have a lot of panels. Rail Clone is one of the most difficult because of the number of panels and the length of each one. It's hard to work without crazy and tedious scrolling without expanding out a bunch of columns. You can also tear the Commands panels off and put them on another screen. That's what I do for Rail Clone so that I can see all the adjustments and have full viewports.
Rob Holmes
R1F
Thank you very much and for the additional info also!  "Open All" and "Close All" definitely makes it a lot easier.  I guess that just leaves the outstanding problem of the rollups resetting every time I close and start up the 3DS Max application.  Is there anyway to keep them closed for when I start it again?
RobH2
Not that I know of. That might be a post for the "Ideas" Forum.
Rob Holmes
