Hi! I cant figure out how to bind this rename layer command to hotkey.
In hotkey editor i didnt find equal position. Tried to manage it by script, but iam near zero in scripting but nothing succeeded
Hope for your help ๐ thanks
Thanks for the answer, but I tried it before and tried it right now again, it doesnt work for me. Checked with keyboard shortcut ovveride toggle on and off, nothing, unfortunatly
Strange.
I tried this under 2022 and it worked(key override on/off doesnt matter). Did you save the keyset? Try with a different key combination? I used Shift+R
Yep, sure iam saving hotkeys. I tried to assign a lot of different combinations no result, now on ctrl+k
I see one strange thing: when i select layer, and after 1 sec clicking again on this layer LMB - rename starts, and then this hotkey works until i select another layer.
Iam using 3ds max 2020.2, maybe there is problems with this ๐
@Anonymous wrote:
Maxscript listener says that macros.run "Scene Explorer" "SERename", but renaming of layer dont starts
OK, so we are talking about renaming Layers? That`s a different thing. I thought you want to rename objects within the layers. Sorry for the confusion.
Seems that you have to make the Layer active for the renaming to start.
Maybe someone in the Programming section of the board can write a macro-script that can make the renaming process easier. Unfortunately i`m no scripter, so i cant help with that.
