3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Hotkey for rename command in scene explorer
9 REPLIES 9
Message 1 of 10
1523 Views, 9 Replies
Hi! I cant figure out how to bind this rename layer command to hotkey.
In hotkey editor  i didnt find equal position. Tried to manage it by script, but iam near zero in scripting but nothing succeeded
Hope for your help 🙂 thanks
Labels (2)
9 REPLIES 9
Message 2 of 10
Search for 'Rename the Selected Nodes' in the Hotkey editor.
Message 3 of 10
Thanks for the answer, but I tried it before and tried it right now again, it doesnt work for me. Checked with keyboard shortcut ovveride toggle on and off, nothing, unfortunatly
Message 4 of 10
Strange.
I tried this under 2022 and it worked(key override on/off doesnt matter). Did you save the keyset? Try with a different key combination? I used Shift+R
Message 5 of 10
Yep, sure iam saving hotkeys.  I tried to assign a lot of different combinations no result, now on ctrl+k
I see one strange thing: when i select layer, and after 1 sec clicking again on this layer LMB - rename starts, and then this hotkey works until i select another layer.
Iam using 3ds max 2020.2, maybe there is problems with this 😞
Message 6 of 10
Maxscript listener says that macros.run "Scene Explorer" "SERename", but renaming of layer dont starts
Message 7 of 10
OK, so we are talking about renaming Layers? That`s a different thing. I thought you want to rename objects within the layers. Sorry for the confusion.
Seems that you have to make the Layer active for the renaming to start.
Message 8 of 10
Yeah, layer renaming in scene explorer.
You are right. Seems like when i select the layer, and then set it to active then rename hotkey works, but if i bind make selected layer active to hotkey and than trying to rename - it doesnt work.
So there is strange thing, that this command works only when you selecting layer with LMB and clicking slowly on it 2 times, or second time on make layer active icon.
That is frustrating, because i have to rename layers a lot during my work, and doing it by RMB-Rename is frustrating extra clicks
Message 9 of 10
Maybe someone in the Programming section of the board can write a macro-script that can make the renaming process easier. Unfortunately i`m no scripter, so i cant help with that.
Message 10 of 10
Anyway thanks for participating! will try your advice
