Hotkey Editor problems
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've just installed update1 for Max2020 and I've noticed a couple issues with the new Hotkey Editor:
- first of all it ruined the current hotkey settings! I guess it reverted all settings to default. I have many custom hotkey, so a warning before installing the update or an automatic conversion of the old hotkeys would be appreciated.
- usually when I do any change in the UI I save it through the 'Save Custom UI Scheme' menu, because it saves most part of the UI. So now when I noticed that my previous hotkeys are lost, I tried to reopen from the save UI scheme and I realized the 3ds max 2020 no longer saves the keyboard with the other settings! So the new update clears the current hotkeys and the Save UI scheme no longer saves it... nice... Luckily I ve found a months old save so I was able to recover it.
- I do save the UI with increments to my raid drive (R:). I wanted to do the same with the new hotkey system and it always points to the same directory on drive C: ( .../Autodesk\3ds Max 2020\User Settings). It would be nice if the 'Save as' window would remember the previous save location, because now I always have to locate the folder manually.
That is all for now, if I encounter any other issue, I will let you know.
Zsombor
