3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Help with extrusion
1 REPLY 1
338 Views, 1 Reply
Help with extrusion
Can anyone let me know how to get this kind of extrusion??..
1 REPLY 1
irishman_team_kilber
how did you create that shape did you use shape merge?
if you shape merged it you should able to convert it down to a poly or add an edit poly modifier then go into the poly mode and then select the shape and extrude it that way.
but it all depends on the shape got up-to the mesh. you should still be able to convert down and then extude the shape as i have said.
