how did you create that shape did you use shape merge?
if you shape merged it you should able to convert it down to a poly or add an edit poly modifier then go into the poly mode and then select the shape and extrude it that way.
but it all depends on the shape got up-to the mesh. you should still be able to convert down and then extude the shape as i have said.
