Grouped Objects not supported in Layer Explorer?
cslyT3MN9
Message 1 of 8
cslyT3MN9
Hi there,
After a preliminary search, I didn't find an answer to this, so hopefully this hasn't been asked before.
I am working with a fairly large scene, in which it is to my advantage to have some objects grouped together, so that I can collapse things in my Scene Explorer to be able to clearly see what is in the scene. For instance, I created a chair, and every piece of the chair is modeled individually and then grouped, so I can move the whole chair around easily.
Now my scene is large enough for me to want to use layers as well, but when I try moving a grouped object from my Scene explorer to a new layer in the Layer Explorer, indeed it works, however the hierarchy of the group is lost in the Layer Explorer, making a long mess of objects group nulls. It doesn't matter that much, as the function of the Layers is handy when I need them, however I'm just wondering why groups wouldn't work in the Layer Explorer too?
Any help would be appreciated.
Replies (7)
Message 2 of 8
Were you able to work out what was causing this? I am having the same issue as well and do not want to see the grouped elements in the Layer Explorer unless i open or ungroup the group.
Message 3 of 8
nvm, after a bit of playing i worked it out by playing with the Display Toolbar. Turning off Display Geometry and Shapes allows me just to see the group and not the objects contained within.
Message 4 of 8
Whilst you found a way to work around the issue, what you did there is not a proper solution as that hides ALL geometry and shapes.
3DS needs a way to collapse groups in the layer manager & not show their contents unless specified.
Message 5 of 8
Agreed. However, what you can do is to configure Advanced filter in a way so only goups are getting displayed. And you can toggle it with a single click:
EDIT: OK, i realized it`s the same like solo (Alt+Group Icon click) the Group property.
Configure Advanced FilterConfigure Advanced Filter
Message 6 of 8
What worked for me was simply selecting sort by Hierarchy
Message 7 of 8
Thanks for the try but that switches over from layer names to object names. This is not the option I'm looking for.
I'm looking for a solution for production in a team environment when you often have 10+ layers with specific names.
If I have 10 groups of 10 objects, I'd much prefer an option to see only 10 object names in the layer manager rather than 100!
It would also be a requirement to see all the other objects that are not group. So solo'ing them as a previous user posted would not work.
Message 8 of 8
Ijustcant
Quite a late reply, but I am experiencing the same problem here.
Some objects in the Layer Explorer are displayed properly as groups and others - like separate objects.
While trying to figure this out, I noticed that the problematic groups consisted of elements which belonged to different layers. I transferred all of them on the same layer (I made it the Active layer), then Ungroup > Group, but the problem is still there
