I had that issue once and I solved it by resetting the 'ENU'. If you've never done that, it's a great way to correct a host of oddities that crop up.
Go to 'C:\Users\%Your User%\AppData\Local\Autodesk\3dsMax\20XX - 64bit\' and find the 'ENU' folder. Rename it so something like 'ENU_ORIGINAL'. Then restart Max. It will build a brand new one. See if things work well. If so and you haven't done much customization of Max, you'll be good to go without too much effort.
If you have customized a lot, there are ways to protect and save a good bit of that configuration. You can search here and Google for info on that. It's out there. But the main thing is to get you going so you can finish your project.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
