3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Graphite Modeling Tools Ribbon opens up huge, how do I restore to default size?
4 REPLIES 4
Kidd_Kosmonaut
1276 Views, 4 Replies
Not sure what I did to create this problem but my graphite modeling tools ribbon now opens up really big when I select one of the panel tiles. How do I restore to its default size?
4 REPLIES 4
RobH2
in reply to: Kidd_Kosmonaut
I had that issue once and I solved it by resetting the 'ENU'. If you've never done that, it's a great way to correct a host of oddities that crop up.
Go to 'C:\Users\%Your User%\AppData\Local\Autodesk\3dsMax\20XX - 64bit\' and find the 'ENU' folder. Rename it so something like 'ENU_ORIGINAL'. Then restart Max. It will build a brand new one. See if things work well. If so and you haven't done much customization of Max, you'll be good to go without too much effort.
If you have customized a lot, there are ways to protect and save a good bit of that configuration. You can search here and Google for info on that. It's out there. But the main thing is to get you going so you can finish your project.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Kidd_Kosmonaut
in reply to: RobH2
Awesome thanks a bunch that did the trick!
I did have some custom menus and scripts but was able to copy that stuff out of the old ENU folder into the new one and then loaded my custom UI and everything is back to how I prefer it to be!
Thank you very much!
RobH2
Alright! I like it when something gets fixed without too much pain. Thanks for the update.
Rob Holmes
3d-Soul
Right-click on the Ribbon toolbar and then select from the opened menu>Ribbon Configuration>Reset Ribbon to default. This worked for me.
______________________________________________________
2*Intel® Xeon® Processor E5-2697 v3 (35M Cache, 2.60 GHz)
32 Gb Ram DDR4 2133
GeForce RTX 3060
Windows 10 64-bit SP1.
3ds Max 2020 64-bit
http://www.3d-soul.net
Mohsen.K.
