3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Fluids Guide Emitter Problem
0 REPLIES 0
Message 1 of 1
ngergihun
336 Views, 0 Replies
Hi All,
I wanted to make some ocean fluid simulation and I run into one issue. I used Hot4Max to create an ocean wave pattern and used it as a guide mesh in the simulation. For the guide emitter, I wanted to use a cylinder as illustrated in my attached image. For some reason, the solver generates the voxel particles above the guide mesh and not below? Can I fix it somehow?
Additional info: When I use the same plane for the guide emitter as for the guide mesh and give some thickness to it, it thickens it upwards and not downwards.
Thank you for your help in advance!
Cheers,
Gergely
Labels (4)
0 REPLIES 0
