3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Extrude, Bevel, Inset, etc... The setting tool works strangely.
1 REPLY 1
Yuseong624
251 Views, 1 Reply
I am writing with a translator.
Anyone know how to solve this problem?
Whenever i encounter this problem while working, i have to restart the program.
Re-running solved the problem, but as I work, I run into this problem again.
[ Problem ]
- Extrude, Bevel, Inset, etc... tools are no problem.
- But if i adjust it with 'settings', it doesn't respond immediately.
- i don't even know if the numbers change.
- Everything reacts in real time from the moment when release the mouse click.
- But only for a very short moment
This is how it feels....
Edit 1)
- I am using 3ds max 2023 version
- Additional update files have been received.
1 REPLY 1
Yuseong624
in reply to: Yuseong624
Find and share a solution to this problem.
It's probably a bug and needs a fix.
1. Open the 'Preferences Settings' window
2. Select the 'General' tab
3. Uncheck 'Enable Caddy Controls' in 'UI Display' area
The UI changes but now it works very well with no issues.
Technology Administrators
