3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Export camera Maya to Max
7 REPLIES 7
Message 1 of 8
3624 Views, 7 Replies
Hi
I have a question about export camera Maya to Max.
When I export camera from Maya , It doesn't fit in Max.
I tried to export abc cache even fbx too. (Camera position, animation is okay, just render view is a bit wide in max.)
I guess it is about camera lens or aov, fov....something..
Also i found post that has same issue before, but no one answer clearly.
How can I match camera in Maya and Max?
Do I need to do something in Maya before export camera?
Tags (5)
7 REPLIES 7
Message 2 of 8
kgokhangurbuz
Hello @Anonymous ;
It's a common issue and there are few scripts for this.
Can you try this script and tell me if it works for you?
Message 3 of 8
in reply to: kgokhangurbuz
It doesn't work...
We tried different setting, didn't work though.
They said unable to convert: undefined to type : Time
Message 4 of 8
kgokhangurbuz
I know this will sound weird but,
can you try and import a 3ds max camera to Maya, then export it back for 3ds max?
Try both of the cameras in 3ds max (Physical and Standard)
Message 5 of 8
Thank you for your help.
I tried that you told me. It is kind of work...but not really...
I think export camera from Max to Maya is okay.
Do you know any other way to work?
Message 6 of 8
kgokhangurbuz
Unfortunately i do not know how to solve this, i have been looking for scripts but no valid result yet.
I'll post if i can find anything.
Message 7 of 8
Thanks!
also if I get some new, i will post it here too
Message 8 of 8
I solved it!
Bake camera every attribute then it gonna be fine
