Export camera Maya to Max
This widget could not be displayed.
Hi
I have a question about export camera Maya to Max.
When I export camera from Maya , It doesn't fit in Max.
I tried to export abc cache even fbx too. (Camera position, animation is okay, just render view is a bit wide in max.)
I guess it is about camera lens or aov, fov....something..
Also i found post that has same issue before, but no one answer clearly.
How can I match camera in Maya and Max?
Do I need to do something in Maya before export camera?
Replies (7)
kgokhangurbuz
Hello @Anonymous ;
It's a common issue and there are few scripts for this.
Can you try this script and tell me if it works for you?
It doesn't work...
We tried different setting, didn't work though.
They said unable to convert: undefined to type : Time
kgokhangurbuz
I know this will sound weird but,
can you try and import a 3ds max camera to Maya, then export it back for 3ds max?
Try both of the cameras in 3ds max (Physical and Standard)
Thank you for your help.
I tried that you told me. It is kind of work...but not really...
I think export camera from Max to Maya is okay.
Do you know any other way to work?
kgokhangurbuz
Unfortunately i do not know how to solve this, i have been looking for scripts but no valid result yet.
I'll post if i can find anything.
Thanks!
also if I get some new, i will post it here too
I solved it!
Bake camera every attribute then it gonna be fine
