3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Exclamation mark and unknown status
11 REPLIES 11
Message 1 of 12
6196 Views, 11 Replies
Hi all
all my last files in the asset tracking i have in the status an unknows status imstead of found or o.k for maps ...
the parth is o.k
someone know why??
ive attached a screenshot.
thanks!
11 REPLIES 11
Message 2 of 12
Steve_Curley
From the Max help...
[exclamation mark icon here] "Status for the file could not be obtained. This typically means you are not logged into the provider."
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 12
BenBisares
in reply to: Steve_Curley
Just to add to Steve_curley's response, does your project use any kind of asset management system like Vault? Also what version of 3ds Max are you using?
Ben Bisares
Message 4 of 12
hey steve what do you mean by : not logged into the provider??
you mean by starting 3dsmax as administrator?
Message 5 of 12
in reply to: BenBisares
hey ben im using 3dsmax design 2014 and its happend in any project i used or model or anything else i dotn have in the status "found" any more..
just unsknoun status
Message 6 of 12
Steve_Curley
That was a direct quote from the help. I didn't say it - the help says it. The "provider" is an asset tracking system such as Vault. Beyond that I know nothing about it.
Max 2016 (SP1/EXT1)
Message 7 of 12
Stefan_L
Since using a renderfarm service (REBUSfarm) and installing their scripts, I too have these exclamation marks.
Optically annoying, but less important than the "Status" column, which is too narrow in your screenshot.
Behind the "status unknown" it tells things like:
"missing" (if not found)
"found" (if found elsewhere)
or nothing, if found in the right place Smiley Happy
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
Message 8 of 12
in reply to: Stefan_L
You must go to Options inside Asset Tracking and click on "Disable Asset Tracking".
Message 9 of 12
Alfred.DeFlaminis
The comments by @Steve_Curley and @BenBisares are correct when referring to Vault protection, and @Anonymous is also correct in that unchecking "Disable asset tracking" will also produce these ! marks.  Marking solutions in this post so future users can benefit from this, thank you all for the excellent posts.
Best Regards,
Message 10 of 12
you are the hero man thanks so much...
Message 11 of 12
I can confirm that this behavior is most likely caused by asset management software. After I installed "Project Manager" from Kstudio Ihad the same behaviour - all marked as "Unknown status", even after uninstalling the software for test reasons. Options --> Disable Asset Tracking is the solution! Thanks!
Workstation: Ryzen 9 5950x@ 4,20GHz 64 GB RAM, Nvidia Quadro P5000, Win10 Prof.
Rendernode: AMD Threadripper 2990wx@ 3,20 GHz 64 GB RAM, Win 10 Prof.
Autodesk Building Design Suite Premium 2021, VRay 5, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
Message 12 of 12
ronilson3d
estou com o mesmo problema
"I have the same problem"
Translated by Google
Traduzido por [@clacampos] através do Google Tradutor
