Hi all
all my last files in the asset tracking i have in the status an unknows status imstead of found or o.k for maps ...
the parth is o.k
someone know why??
ive attached a screenshot.
thanks!
Solved by Steve_Curley. Go to Solution.
Just to add to Steve_curley's response, does your project use any kind of asset management system like Vault? Also what version of 3ds Max are you using?
hey steve what do you mean by : not logged into the provider??
you mean by starting 3dsmax as administrator?
hey ben im using 3dsmax design 2014 and its happend in any project i used or model or anything else i dotn have in the status "found" any more..
just unsknoun status
Since using a renderfarm service (REBUSfarm) and installing their scripts, I too have these exclamation marks.
Optically annoying, but less important than the "Status" column, which is too narrow in your screenshot.
Behind the "status unknown" it tells things like:
"missing" (if not found)
"found" (if found elsewhere)
or nothing, if found in the right place
The comments by @Steve_Curley and @BenBisares are correct when referring to Vault protection, and @Anonymous is also correct in that unchecking "Disable asset tracking" will also produce these ! marks. Marking solutions in this post so future users can benefit from this, thank you all for the excellent posts.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I can confirm that this behavior is most likely caused by asset management software. After I installed "Project Manager" from Kstudio Ihad the same behaviour - all marked as "Unknown status", even after uninstalling the software for test reasons. Options --> Disable Asset Tracking is the solution! Thanks!
estou com o mesmo problema
"I have the same problem"
Translated by Google
Traduzido por [@clacampos] através do Google Tradutor
