Hi , about 1 week i try to install some version of auto desk 3DSMAX but , all installation failed i have the last net framework 4 direct x i'm on windows7 32 BIT need help please Thanks!
LOG FILE HERE :
2011/5/12:09:17:20 Marwan MARWAN-PC === Setup started on MARWAN-PC by Marwan ===
2011/5/12:09:17:20 Marwan MARWAN-PC Launch
2011/5/12:09:18:24 Marwan MARWAN-PC === Setup ended ===
2011/5/12:09:17:21 Marwan MARWAN-PC === Setup started on MARWAN-PC by Marwan ===
2011/5/12:09:17:21 Marwan MARWAN-PC Launch
2011/5/12:09:18:24 Marwan MARWAN-PC PageOpen LaunchDialog
2011/5/12:09:19:24 Marwan MARWAN-PC PageOpen LicenseDialog
2011/5/12:09:19:46 Marwan MARWAN-PC PageOpen ProductInfoDialog
2011/5/12:09:19:58 Marwan MARWAN-PC PageOpen ProductSelectionDialog2
2011/5/12:09:20:11 Marwan MARWAN-PC PageOpen FullProgressDialog
2011/5/12:09:20:12 Marwan MARWAN-PC Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2011/5/12:09:22:14 Marwan MARWAN-PC Install DirectX® Runtime Succeeded
2011/5/12:09:22:15 Marwan MARWAN-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Marwan\AppData\Local\Temp\_AI7465.tmp\Media.mst"
2011/5/12:09:23:12 Marwan MARWAN-PC Install Autodesk Material Library 2012 Succeeded
2011/5/12:09:23:16 Marwan MARWAN-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Marwan\AppData\Local\Temp\_AI7465.tmp\Media.mst"
2011/5/12:09:24:04 Marwan MARWAN-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2011/5/12:09:24:05 Marwan MARWAN-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Marwan\AppData\Local\Temp\_AI7465.tmp\Media.mst"
2011/5/12:09:27:41 Marwan MARWAN-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2011/5/12:09:27:41 Marwan MARWAN-PC Installing Autodesk® Backburner 2012: H:\x86\Components\backburner\BackburnerCIF.exe
2011/5/12:09:27:44 Marwan MARWAN-PC Install Autodesk® Backburner 2012 Succeeded
2011/5/12:09:27:46 Marwan MARWAN-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Marwan\AppData\Local\Temp\_AI7465.tmp\x86\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/12:09:28:15 Marwan MARWAN-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2011/5/12:09:28:15 Marwan MARWAN-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2011/5/12:09:29:18 Marwan MARWAN-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2011/5/12:09:29:52 Marwan MARWAN-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2011/5/12:09:30:33 Marwan MARWAN-PC Rollback Autodesk Material Library 2012 Succeeded
2011/5/12:09:30:33 Marwan MARWAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2011/5/12:09:30:34 Marwan MARWAN-PC PageOpen InstallCompleteDialog
2011/5/12:09:33:11 Marwan MARWAN-PC === Setup ended ===
2011/5/12:12:42:52 Marwan MARWAN-PC === Setup started on MARWAN-PC by Marwan ===
2011/5/12:12:42:52 Marwan MARWAN-PC Launch
2011/5/12:12:43:58 Marwan MARWAN-PC === Setup ended ===
2011/5/12:12:42:53 Marwan MARWAN-PC === Setup started on MARWAN-PC by Marwan ===
2011/5/12:12:42:53 Marwan MARWAN-PC Launch
2011/5/12:12:44:05 Marwan MARWAN-PC PageOpen LaunchDialog
2011/5/12:12:51:22 Marwan MARWAN-PC PageOpen LicenseDialog
2011/5/12:12:53:17 Marwan MARWAN-PC PageOpen ProductInfoDialog
2011/5/12:12:53:35 Marwan MARWAN-PC PageOpen ProductSelectionDialog2
2011/5/12:12:53:46 Marwan MARWAN-PC PageOpen FullProgressDialog
2011/5/12:12:53:47 Marwan MARWAN-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2012_French_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/5/12:12:54:49 Marwan MARWAN-PC Install DirectX® Runtime Succeeded
2011/5/12:12:54:49 Marwan MARWAN-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_French_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/12:12:55:29 Marwan MARWAN-PC Install Autodesk Material Library 2012 Succeeded
2011/5/12:12:55:29 Marwan MARWAN-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_French_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/12:12:56:14 Marwan MARWAN-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2011/5/12:12:56:14 Marwan MARWAN-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_French_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/12:12:58:06 Marwan MARWAN-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2011/5/12:12:58:06 Marwan MARWAN-PC Installing Autodesk® Backburner 2012: C:\Autodesk\Autodesk_3ds_Max_2012_French_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2011/5/12:12:58:10 Marwan MARWAN-PC Install Autodesk® Backburner 2012 Succeeded
2011/5/12:12:58:11 Marwan MARWAN-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Marwan\AppData\Local\Temp\_AIA0C5.tmp\x86\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_French_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/5/12:12:58:27 Marwan MARWAN-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2011/5/12:12:58:27 Marwan MARWAN-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2011/5/12:12:59:01 Marwan MARWAN-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2011/5/12:12:59:38 Marwan MARWAN-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2011/5/12:13:00:20 Marwan MARWAN-PC Rollback Autodesk Material Library 2012 Succeeded
2011/5/12:13:00:21 Marwan MARWAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
![](http://area.autodesk.com/userdata/forum/s/sans_titre.png)
