'Edit Vertices' is absent in the menu bar.
shadowdemocrat
shadowdemocrat
Community Visitor
Community Visitor
If I make a standard primitive like a box and convert it into an editable object I can edit its vertices. I see 'Weld' and 'Target Weld' in the menu bar. In another case, if I make lines and Sweep them into a poly object then I can't edit its vertices. I don't see 'Weld' and 'Target Weld' in the menu bar in latter.
How to fix it? What should I do with editing vertices of a line object, please?
Thank you!
RobH2
Put an 'Edit Poly' modifier on top of that new Editible Poly and see if you get your controls back.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
