Edit Poly modifier missing
Message 1 of 9
Hello guys, I can't fine the Edit Poly modifier from the Modifier list so instead I go to Modifiers -> Mesh Editing -> Edit Poly and I added that way.  But any idea why the Edit Poly modifier does not appear in the Modifier List?
I'm using 3ds 2018 student
Thank you
Replies (8)
Message 2 of 9
RobH2
Go to 'C:\Users\%Your User%\AppData\Local\Autodesk\3dsMax\2019 - 64bit\' and find the 'ENU' folder. Rename it so something like 'ENU_ORIGINAL'. Then restart Max. It will build a brand new one. See if the icon comes back. If so and you haven't done much customization of Max, you'll be good to go without too much effort.
If you have customized a lot, there are ways to protect and save a good bit of that configuration. You can search here and Google for info on that. It's out there. But the main thing is to get you going so you can finish your project.
By saving the original ENU above, you can always get back to that somewhat broked state if you need to. Just delete the new one you made, rename the original one back to just 'ENU' and restart Max.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 3 of 9
I can't find that ENU folder. I can't even find the AppData folder no matter where I look. I went to program files and there too I couldn't find anything. I can go C:\Users\%Your User%\ and then I find an autodesk folder, then -> 3ds max 2018 and inside that folder are only two folders Max Creation Graph and Scene Converter . Should I re-install?
Message 4 of 9
Just a note here, I can find the edit poly modifier when I open the Configure Modifier Sets it is under Max Edit. But still I can't find it on the modifier list.
Message 5 of 9
RobH2
That's odd. I wouldn't reinstall yet. If you can't see AppData at all that's a global problem with Windows and not a Max issue. There's a setting in Windows 10 that allows you to see/hide system files and data if I recall. That keeps people from accidentally causing damage to the OS files. See if yours is set so that you can't see the OS system files.
Here's my path to ENU. It should be the same for each user.
C:\Users\YourUsername\AppData\Local\Autodesk\3dsMax\2020 - 64bit\ENU
Rob Holmes
Message 6 of 9
RobH2
Try this before you reinstall.
https://www.technipages.com/show-hidden-files-windows
Rob Holmes
Message 7 of 9
Did it! You're a saver! Thanks a ton!
Message 8 of 9
RobH2
Excellent, now you are rolling again.
Now, once you get Max all settled in and working the way you want, copy that ENU and save it somewhere. Then the next time you have some kind of 'oddity' happen, just put it in the folder in place of the ENU that's there when Max acts up again. It's saved me dozens of times and saved me from having to redo a bunch of customizations in Max's interface.
Rob Holmes
Message 9 of 9
Aha, go it! Thanks for telling me. Very important.
