I am having issues with a new 3ds max 2017 install and my FirePro W7000 display card. Viewport geometry is not appearing correctly. Objects that are closer to the camera appear behind other objects and look inside-out. It's not a back culling issue as I've tried that. If I select the object, it will move back in front in the display.
In the attached capture, the rear leg of the chair on the right should be sitting behind the chair back as the one on the right is. however, it appears to be under the seat. You also note that the structure under the seat appears to be above the seat.
Any suggestions?
Solved by Alfred.DeFlaminis. Go to Solution.
Yes, in all views... I've attached a screen capture of how it behaves if the view is rotated... notice that the legs move in and out.
Hi, is it possible to pack and attach this scene please?
Never saw this kind of problem before, i suspect that this file may work on my test computers. We just need to confirm if this is a file problem or a problem with your configuration.
Thanks!
Hmmm... in packing it up I think I discovered the problem. I am using VRScan materials for the wood and when I apply a standard material the problem goes away. I think I need to post this issue with Chaos Group.
Thanks for your response!
Hello @Anonymous and welcome to the community,
I know that the VRScans are sort of uneditable materials, or they were last time I read up on them. While this issue may exist in those scan mats, I have seen something like this before with a zsorting issue on the low quality viewport.
On a hunch, what happens if you turn on advanced rendering as shown below? Thanks for trying that!
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Thanks Alfred, that did work and clear-up the issue! I sent the original issue to Chaos Group and they were able to reproduce the problem and have noted it as a bug to be fixed. I will pass this solution along to them.
Thank you for your response!
Thank you very much for the update @Anonymous! I have also marked your post since it contains a solution as well. Thanks so much for taking the time to update me.
Best Regards,
I discovered that the problem also exists with standard Vray materials. Note the cloth seat material in the attached image. This issue was not fixed by changing per view settings to advanced. I have completely removed all traces of the display driver and installed the latest one with out any change in performance.
Hello @Anonymous,
I could create a private folder for you if you'd like so I can look at the chair model on this end to see if I can also repro this. Would you be able to share the model file with me?
Best Regards,
