DirectX 11 RT Shader - Render to Target
lhoyet
Message 1 of 1
lhoyet
I've been hitting a wall for 2 days trying to render to different render target using FX hlsl shaders in 3DS MAX...
I've come up to this simple 3 passes shader that 1) render the scene in green in a target, 2) render the same scene in red in another target, 3) combine the information of both in a last pass...
This basically gives:
Pass 1                                                      Pass 2                                     Expected Pass 3
The problem is that I get the following result, which seems to show that results of the different passes are not rendered in the RenderTarget textures :S
I think I have kind of pinned down the problem to be that 3DS Max does not execute the parts defined in the string Script, such as the following block of code. I think this is the case because ClearColor is always white for instance, even if I set it to red...
string Script =
			"RenderColorTarget1=TargetTextureGreen;"
			"ClearSetColor=ClearColor;"
			"ClearSetDepth=ClearDepth;"
			"Clear=Color;"
			"Clear=Depth;"
			"Draw=geometry;";
I've also created a second shader to see what happens if I do not draw a specific object (the floor plane) in the last pass, and I end up seeing the green pixels underneath, which means that the Color buffer was not cleared...
I paste the full code of the shader below in case someone has any idea :S
Cheers,
string ParamID = "0x0003";
float4 ClearColor : DIFFUSE = {1,0,0,1.0};
float  ClearDepth = 1.0;
float NearClip = 0.01f;
float FarClip = 250.0f;
//// UN-TWEAKABLES - AUTOMATICALLY-TRACKED TRANSFORMS ////////////////
float4x4 WvpXf : WorldViewProjection < string UIWidget="None"; >;
float4x4 WorldXf : World < string UIWidget="None"; >;
float4x4 ViewXf : View < string UIWidget="None"; >;
float4x4 ProjXf : Projection < string UIWidget="None"; >;
#ifdef _MAX_
int texcoord1 : Texcoord
	int Texcoord = 1;
	int MapChannel = 0;
	string UIWidget = "None";
int texcoord2 : Texcoord
	int Texcoord = 2;
	int MapChannel = -2;
int texcoord3 : Texcoord
	int Texcoord = 3;
	int MapChannel = -1;
#endif
bool g_draw <
	string UIName = "Draw for mix technique";
> = true;
//// TWEAKABLE PARAMETERS ////////////////////
Texture2D TargetTextureRed : RENDERCOLORTARGET
	float2 ViewportRatio = { 1.0, 1.0 };
Texture2D TargetTextureGreen : RENDERCOLORTARGET
SamplerState g_TargetTextureRedSampler
	Filter = MIN_MAG_MIP_LINEAR;
	AddressU = Clamp;
    AddressV = Clamp;
SamplerState g_TargetTextureGreenSampler
	AddressU = Clamp;
    AddressV = Clamp;
/* data from application vertex buffer */
struct appdata {
	float4 Position		: POSITION;
	float3 Normal		: NORMAL;
	float3 Tangent		: TANGENT;
	float3 Binormal		: BINORMAL;
	float2 UV0			: TEXCOORD0;
/* data passed from vertex shader to pixel shader */
struct vertexOutput {
    float4 Position	: SV_Position;
///////// VERTEX SHADING /////////////////////
/*********** Generic Vertex Shader ******/
vertexOutput std_VS(appdata IN) {
    vertexOutput OUT = (vertexOutput)0;
    float4 Po = float4(IN.Position.xyz,1);
    float4 Pw = mul(Po,WorldXf);
	float4 Pv = mul(Pw,ViewXf);
	float4 Pj = mul(Pv,ProjXf);
	float4x4 projCorrected = ProjXf;
	projCorrected[2].z = (FarClip + NearClip)/(NearClip- FarClip);
	projCorrected[3].z = (2 * FarClip * NearClip)/(NearClip - FarClip);
	Pj = mul(Pv,projCorrected);
	OUT.Position = Pj;
	OUT.UV0 = IN.UV0;
	return OUT;
vertexOutput mix_VS(appdata IN) {
	OUT.Position = Pj;
	OUT.UV0 = IN.UV0;
	if(!g_draw)
		OUT.Position.z = 10 * OUT.Position.w; // Outside cliping volume
	return OUT;
///////// PIXEL SHADING //////////////////////
float4 red_PS(vertexOutput IN) : SV_Target
	return float4(1.0,0.0,0.0,1.0);
float4 green_PS(vertexOutput IN) : SV_Target
	return float4(0.0,1.0,0.0,1.0);
float4 mix_PS(vertexOutput IN) : SV_Target
	float r = TargetTextureRed.Sample(g_TargetTextureRedSampler, IN.UV0);
	float g = TargetTextureGreen.Sample(g_TargetTextureGreenSampler, IN.UV0);
	return float4(r,g,0.0,1.0);
///// TECHNIQUES /////////////////////////////
float Script : STANDARDSGLOBAL <
    string UIWidget = "none";
    string ScriptClass = "scene";
    string ScriptOrder = "postprocess";
    string ScriptOutput = "color";
    string Script = "Technique=Main;";
> = 0.8;
technique11 Main <
	string Script =
			"Clear=Color;"
			"Pass=Red;"
			"Pass=Green;"
			"Pass=Mix;";
	pass Red <
	string Script =
			"RenderColorTarget0=TargetTextureRed;"
			"ClearSetColor=ClearColor2;"
			"Clear=Color;"
			"Clear=Depth;"
			"Draw=geometry;";
		SetVertexShader(CompileShader(vs_5_0,std_VS()));
        SetGeometryShader( NULL );
		SetPixelShader(CompileShader(ps_5_0,red_PS()));
	pass Green <
	string Script =
			"Clear=Color;"
			"Clear=Depth;"
			"Draw=geometry;";
		SetPixelShader(CompileShader(ps_5_0,green_PS()));
	pass Mix <
	string Script =
			"RenderColorTarget0=;"
			"Clear=Color;"
			"Clear=Depth;"
			"Draw=Buffer;";
	SetVertexShader(CompileShader(vs_5_0,mix_VS()));
	SetPixelShader(CompileShader(ps_5_0,mix_PS()));
Replies (0)
