3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Curve Spline Extend
3 REPLIES 3
calberto.cart
373 Views, 3 Replies
Curve Spline Extend
Hi there, Is there any possible way to extend a curved Spline?
The main option only extend as a linear, in this example Im using the Trim/Extend Modifier.
Labels (3)
3 REPLIES 3
leeminardi
in reply to: calberto.cart
The short answer is no.  If a curved extension were to be done which one of the infinite options would you want?  The one that curves up or down gradually or more steeply?  How about a curve that has a little bounce?  I would probably use the linear extension then drag the end vertex to another point along the trimmin line.
lee.minardi
calberto.cart
in reply to: leeminardi
Well I would like to take into account the center coordinate and complete the radius, I think that the issue here is that every primitive loose its properties since its converted to Editable poly or spline.
Diffus3d
It doesn't have to be converted, you could put Edit Polys or Edit Splines on top of the primitive object in the stack.  May not apply here though...
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
