crashes while render
Aviva01
Message 1 of 16
Aviva01
please help me to find solution for below error
Application: 3dsmax.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: MNMath.dll
Exception Address: 0x00007ffea60563c5
Exception Code: c0000005
Replies (15)
Message 2 of 16
darawork
This looks like an 'out-of-memory' error (MNMath.dll is writing memory to disk, disk might be full or RAM runs out, either way something is causing a memory leak/overflow), from possibly having a dodgy material or mesh in your scene. Looks like you're going to have to strip the scene to find the culprit.
You can do this by halving the scene, try render again, if it crashes, halve it again... until it doesn't crash.
This is pretty much the only way to find out what is causing the bad geometry or material.
Unless you might have an idea what the bad geometry or material might be?
Some more clues here.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Message 3 of 16
Aviva01
hi dara,
even when we halve the scene and change meterial its crashing.
Message 4 of 16
Aviva01
hi dara,
even when we halve the scene and change material its crashing.
Message 5 of 16
Aviva01
(view in My Videos)
Message 6 of 16
darawork
Which rendering engine are you using? Can you possibly try to turn on the material override setting?
This might let you be able to work out if it's a material problem or a geometry problem.
Is it still giving the exact same error?
Also are the computer specs above the recommended for 3DSMax?
Dedicated Graphics card, enough RAM, etc...
Darawork
AutoDesk User
Message 7 of 16
Aviva01
Ram 128GB
Processor i9 12 th gen
Nvidia 12GB 40series
rendering engine vray
Message 8 of 16
darawork
Ok,
Seems like a very capable workstation.
My only other advice would be perhaps go through these links here
to see if anything sounds similar and hopefully you can find a solution.
It seems to crashing out at the pre-processing stage, where it is gathering information about the scene, so maybe check your vRay proxies to see if there is any corruption there?
Darawork
AutoDesk User
Message 9 of 16
Aviva01
im reinstalling 3ds max and im facing issue and error
Date/Time: 2023-12-01 13:58:56 +04:00
Application: install_manager.exe
Crashed Module Name: install_operation_library.dll
Exception Address: 0x00007fff6494b754
Exception Flags: 0
Exception Parameters: 0, 8
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall.ht...
kindly advice
Message 10 of 16
Aviva01
Exception Flags: 0
kindly advice
Message 11 of 16
Aviva01
every time install different error
below is error while installing 3dmax2022
Message 12 of 16
Aviva01
we have installed 3dsmax2024 update 2 and vray 62000 latest update
still we have error.
the scene which we render is created in 2022 3dsmax version is that an issue?
Message 13 of 16
236298127
Observer
Observer
I also encountered the same problem. Have you solved it
Message 14 of 16
lovepreetmoga4577
Community Visitor
Community Visitor
help
Message 15 of 16
lovepreetmoga4577
Community Visitor
Community Visitor
help me
Message 16 of 16
Casey_H_
Re-image the pc and reinstall everything. If error persists, contact Autodesk Support  😏
