Cloth Modifer and Rubber
mattsimecek
mattsimecek
are there correct settings in the Cloth Modifier to get a geometry to have an "Elastic Effect"?....like hard rubber or a rubber band
One way would be using mCloth, which is part of 3DS Max's Mass FX toolset. I haven't used mCloth specifically very much, but it seems possible, perhaps by keyframing different states of the cloth. To show the MassFX toolbar right-click an empty area of the main toolbar, and select MassFX Toolbar from the dropdown.
Here is the reference for Mass FX:
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/3DSMa...
Reference for mCloth Modifier
In the Physical Fabric Properties rollout there is a stretchiness rollout. This video shows how to attach nodes to pull apart the verts of your cloth mesh.
https://youtu.be/1zPQkw8Azaw?t=186
mattsimecek
an interesting solution... i guess this means there are no settings in either cloth or mcloth the replicate rigid rubber.
ok. i'll definitely give this solution a good look.
thanks for the advice
