Curve Editor loop question
Message 1 of 9
This question is two part
1. what would cause loop to not work. (see attached video)
2. How can I access the loop option from the default menu? I am constantly switching between default and Funtion curve layout menu
Thanks a bunch!
Replies (8)
Message 2 of 9
1) You need 'relative repeat' for a constant rotation.
2) Don`t know. Here it defaults to 'Function Curve Layout' that i checked in the Layout section.If you check Rightclick->Show toolbars->Curves: Trackview you can get the toolbar with this option. It should stick.At least here it does.
Message 3 of 9
thanks! the show show tool bars did the trick for the curves section.
no I have another problem. When i go into my track view i see no operations.I have scrolled and zoomed and don't see a thing. If I go in and out of default menu it shows up. is this a bug?
Message 4 of 9
What do you mean with 'operations' ?
Message 5 of 9
The actual curves and node points. nothing is showing up in the track view. Is there a zoom all or possibly another show graph toolbar switch?
Message 6 of 9
here is what I am talking about.
Message 7 of 9
oops sorry i see i had manual nav selected.
Message 8 of 9
here is what i was talking about with loop not working. I tried Relative repeat and that does not work as well
Message 9 of 9
Strange.
Does it work at all? On a newly created fresh object? Or only on this specific object?
