3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
change polygons to similar size, more like square
2 REPLIES 2
980 Views, 2 Replies
hey, I need to change polygons visible on picture to square shape (I marked in green colour what polygons I need, in red colour examples of which I need to split, and black lines how I would want to split it), but "connect" or "tesselate" is splitting every polygon, also these which are already square shape. How I can achieve it for whole shape? I would need something similar to "normalise spline" but which works for 2d shape, changing all long polygons to more equal elements, like squares.
2 REPLIES 2
CiroCardoso3v
Select the edges and then use the Connect option.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Thanks, that helps if there is single group, however not if there are multiple groups of different sizes polygons. I found solution after several days, it was modifier "quadify mesh", I am posting here hoping that maybe it will be useful for someone in the future.
