hey, I need to change polygons visible on picture to square shape (I marked in green colour what polygons I need, in red colour examples of which I need to split, and black lines how I would want to split it), but "connect" or "tesselate" is splitting every polygon, also these which are already square shape. How I can achieve it for whole shape? I would need something similar to "normalise spline" but which works for 2d shape, changing all long polygons to more equal elements, like squares.
Select the edges and then use the Connect option.
Thanks, that helps if there is single group, however not if there are multiple groups of different sizes polygons. I found solution after several days, it was modifier "quadify mesh", I am posting here hoping that maybe it will be useful for someone in the future.
